[postgis-tickets] [PostGIS] #2485: [raster]: SQL functions namespace qualification
PostGIS trac at osgeo.org
Mon Sep 23 08:40:51 PDT 2013
 Reporter:  rdunklau  |       Owner:  dustymugs
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.5
Component:  raster    |     Version:  2.0.x
 Keywords:            |
Comment(by rdunklau):
 Using @extschema@ to refer to the extension schema may accomodate both
 use.
 The extension will be installable in another schema. However, the
 extension will not be fully-relocatable: the `ALTER EXTENSION POSTGIS set
 schema` statement will not work.
 The PostgreSQL documentation about extensions explains this better than I
 can:
 http://www.postgresql.org/docs/current/static/extend-
 extensions.html#AEN54999
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:2>
