[postgis-tickets] [PostGIS] #2485: [raster]: SQL functions namespace qualification
PostGIS trac at osgeo.org
Mon Sep 23 08:47:59 PDT 2013
 Reporter:  rdunklau  |       Owner:  dustymugs
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.5
Component:  raster    |     Version:  2.0.x
 Keywords:            |
Comment(by robe):
 Other functions at issue at a cursory glance I think these are the only
 problematic ones.
 _raster_constraint_info_regular_blocking
 _raster_constraint_nodata_values
 _raster_constraint_out_db
  As noted by rdunklau, I think with extension install, there is a way to
 grab the chosen extension and add that as a search_path of the function,
 but not with old way of installing. Anyway it sounds kinda messy even with
 extension. The ideal solution is avoiding calling other none pg_catalog
 functions from the constraints.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:3>
