[postgis-tickets] [PostGIS] #2648: Missing schema name in ST_GetFaceGeometry function call to topology table
PostGIS trac at osgeo.org
Fri Feb 21 18:35:30 PST 2014
 Reporter:  pauldzy   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.2
Component:  topology  |     Version:  2.1.x
 Keywords:            |
Comment(by robe):
 Paul,
 Are you having a problem with that.  I don't think any of the logic in
 topology is schema qualified anymore.  It should work unless you have
 another topology table in another schema or topology is not in your
 search_path. Topology not being in your search_path would cause all sorts
 of other problems.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2648#comment:1>
