[postgis-tickets] [PostGIS] #2648: Missing schema name in ST_GetFaceGeometry function call to topology table
PostGIS trac at osgeo.org
Fri Feb 21 19:00:48 PST 2014
  Reporter:  pauldzy   |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.1.2
 Component:  topology  |     Version:  2.1.x
Resolution:  fixed     |    Keywords:
Changes (by pauldzy):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Hi there,
 Yes without the schema qualifier, things were failing in ValidateTopology.
 You are correct that topology is not on any of my user search paths.  Is
 that a manual step we need to do on our own as part of using the topology
 extension?  Okay can do.  That should probably be noted somewhere in the
 docs as the code seems to flip back and forth on whether to qualify
 references to topology.
 Thanks for the fast response.
 Cheers,
 Paul
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2648#comment:2>
