[postgis-tickets] [PostGIS] #2595: Setup job to pull transifex translations and build
PostGIS trac at osgeo.org
Fri Jan 3 21:58:18 PST 2014
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.2.0
Component:  buildbots  |     Version:  2.1.x
 Keywords:             |
 Now that transifex translations are in full swing. It will be nice to see
 these translating into pdfs and html docs.
 https://www.transifex.com/projects/p/postgis-1/r/all-resources/
 Particularly the italian and french which are around 20% already.
 So far on Debbie, I have installed the transifex client (tx), and looking
 thru the pgrouting transifex strips to glean any tips on how they do their
 pulls.
 I think the way strk has it in theory once I have the transifex
 configuration files setup, it should be just a matter of setting up the
 doc job to pull into doc folder and running the translation doc command he
 has already.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2595>
