[postgis-tickets] [PostGIS] #2595: Setup job to pull transifex translations and build
PostGIS trac at osgeo.org
Fri Jan 3 21:58:58 PST 2014
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.2.0
Component:  buildbots  |     Version:  2.1.x
 Keywords:             |
Description changed by robe:
Old description:
> Now that transifex translations are in full swing. It will be nice to see
> these translating into pdfs and html docs.
> https://www.transifex.com/projects/p/postgis-1/r/all-resources/
> Particularly the italian and french which are around 20% already.
> So far on Debbie, I have installed the transifex client (tx), and looking
> thru the pgrouting transifex strips to glean any tips on how they do
> their pulls.
> I think the way strk has it in theory once I have the transifex
> configuration files setup, it should be just a matter of setting up the
> doc job to pull into doc folder and running the translation doc command
> he has already.
New description:
 thru the pgrouting transifex scripts to glean any tips on how they do
 their pulls.
 doc job to pull into doc folder and running the translation doc command he
 has already.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2595#comment:1>
