[postgis-tickets] [PostGIS] #2614: Prepared geometry support for ST_DWithin
PostGIS trac at osgeo.org
Mon Jan 20 11:47:05 PST 2014
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
 In some cases, despite what we tell people, doing an
 ST_Intersects(geom1, ST_Buffer(geom2,radius))
 is sometimes faster than ST_DWithin(geom1,geom2)
 Granted ST_DWithin is faster.
 I'll come up with a small self-standing example to demonstrate the point.
 The one I have currently is kind of hefty.
 But basic assumption is if you have a fairly large constant geometry then
 ST_Intersects(ST_Buffer..) often out performs ST_DWithin.  I assume this
 is because ST_Intersects takes advantage of prepared geometries and
 ST_DWithin does not.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2614>
