[postgis-tickets] [PostGIS] #2614: Prepared geometry support for ST_DWithin
PostGIS trac at osgeo.org
Mon Jan 20 15:11:38 PST 2014
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Description changed by robe:
Old description:
> In some cases, despite what we tell people, doing an
> ST_Intersects(geom1, ST_Buffer(geom2,radius))
> is sometimes faster than ST_DWithin(geom1,geom2)
> Granted ST_DWithin is faster.
> I'll come up with a small self-standing example to demonstrate the point.
> The one I have currently is kind of hefty.
> But basic assumption is if you have a fairly large constant geometry then
> ST_Intersects(ST_Buffer..) often out performs ST_DWithin.  I assume this
> is because ST_Intersects takes advantage of prepared geometries and
> ST_DWithin does not.
New description:
 is sometimes faster than ST_DWithin(geom1,geom2, radius)
 Granted ST_DWithin is more accurate.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2614#comment:1>
