[postgis-tickets] [PostGIS] #2592: AddNode(atopology, apoint) redundant
PostGIS trac at osgeo.org
Tue Jan 28 10:56:05 PST 2014
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  low       |   Milestone:  PostGIS 2.2.0
Component:  topology  |     Version:  2.1.x
 Keywords:            |
Comment(by strk):
 That's the result of my lazy way to deal with upgrades.
 Adding an optional parameter doesn't replace the old signature, so in
 order to do a clean upgrade you'd have to _drop_ the previous, which is
 not something you do in an install file.
 When I'm willing to provide a single .sql to do both install and upgrade
 (because I'm lazy) that's what I do: never drop any signature, and if I
 need more parameters keep the old one as wrappers that call the new one
 passing the defaults. This has been working since PostGIS-1.0 against
 PostgreSQL 6.X ...
 Keep it simple!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2592#comment:1>
