[postgis-tickets] [PostGIS] #2618: Use geodetic calculations from Proj 4.9
PostGIS trac at osgeo.org
Tue Jan 28 13:32:06 PST 2014
 Reporter:  pramsey      |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
 As of proj4.9, geodetic distance and area on spheroid will be available
 from proj4
 http://gis.stackexchange.com/questions/84012/how-can-i-obtain-the-same-
 area-values-provided-by-the-census-for-tiger-boundarie
 The area in particular does not have failure cases around the poles or
 over the equator, so would be an improvement on the current code. Could
 also copy the code directly into liblwgeom for support on earlier versions
 of proj.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2618>
