[postgis-tickets] [PostGIS] #2382: Can't upgrade postgis ERROR: attempt to redefine parameter "postgis.backend"
PostGIS trac at osgeo.org
Wed Jun 18 05:20:02 PDT 2014
"postgis.backend"
  Reporter:  robe                   |       Owner:  pramsey
      Type:  defect                 |      Status:  reopened
  Priority:  blocker                |   Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:
Comment(by vmo):
 @strk: I tried your test:
  make -C topology check RUNTESTFLAGS='-v --extension --upgrade-path 2.1.2
 --2.2.0dev'
 and it only fails at:
  uninstall .. failed (Object count pre-install (4112) != post-uninstall
 (4113))
 The result is the same with and without the changes in lwgeom_init_backend
 from r12350.
 Which version of postgresql did you use ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2382#comment:30>
