[postgis-tickets] [PostGIS] #2382: Can't upgrade postgis ERROR: attempt to redefine parameter "postgis.backend"
PostGIS trac at osgeo.org
Wed Jun 18 05:54:08 PDT 2014
"postgis.backend"
  Reporter:  robe                   |       Owner:  pramsey
      Type:  defect                 |      Status:  reopened
  Priority:  blocker                |   Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:
Comment(by strk):
 PostgreSQL 9.3.4+, just tried again now and confirm the same problem
 (attempt to redefine parameter "postgis.backend").
 Remember you have to install postgis in order to get the extension-based
 upgrade to use the latest upgrade script.
 I'm using r12618
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2382#comment:31>
