[postgis-tickets] [PostGIS] #2382: Can't upgrade postgis ERROR: attempt to redefine parameter "postgis.backend"
PostGIS trac at osgeo.org
Wed Jun 18 06:11:42 PDT 2014
"postgis.backend"
  Reporter:  robe                   |       Owner:  pramsey
      Type:  defect                 |      Status:  reopened
  Priority:  blocker                |   Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:
Comment(by vmo):
 Thanks for the 'Remember', I'm able to reproduce now.
 The fix in r12350 don't actually fix this, but prevents the loading of
 sfcgal backend. I think r12350 is responsible for some of the diff in
 #2755: some output (e.g. ST_Distance(geom, empty)) comes from geos
 functions that are not properly replaced by sfcgal ones.
 The result from your test is apparently the same with/without r12350
     svn merge -r 12350:12349 .
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2382#comment:32>
