[postgis-tickets] [PostGIS] #2763: point WKB doesn't work when lower case
PostGIS trac at osgeo.org
Wed Jun 18 09:34:24 PDT 2014
 Reporter:  jmccormick2001  |       Owner:  pramsey
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:
Component:  postgis         |     Version:  2.1.x
 Keywords:                  |
 I'm trying to run postgis 2.1.3 on fedora 20, 2 regression tests fail, one
 of them is regress_index_nulls, I've found the following to be happening
 in reference to the lower case 'point' as referenced in the
 regress_index_nulls.sql test case:
 [postgres at localhost regress]$ psql
 psql (9.3.4)
 Type "help" for help.
 postgres=# select 'POINT(0 0)'::geography;
                      geography
  0101000020E610000000000000000000000000000000000000
 (1 row)
 postgres=# select 'point(0 0)'::geography;
 ERROR:  parse error - invalid geometry
 LINE 1: select 'point(0 0)'::geography;
 HINT:  "po" <-- parse error at position 2 within geometry
 postgres=# select postgis_v
 postgres=# select postgis_full_version();
 NOTICE:  Function postgis_topology_scripts_installed() not found. Is
 topology support enabled and topology.sql installed?
 postgis_full_ve
 rsion
  POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
 March
  2012" GDAL="GDAL 1.11.0, released 2014/04/16" LIBXML="2.9.1" RASTER
 (1 row)
 postgres=#
 For some reason I can't figure out, when using the lower case spelling of
 'point', it fails, upper case works as expected.
 this is on postgres 9.3.4.
 thanks
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2763>
