[postgis-tickets] [PostGIS] #2763: point WKB doesn't work when lower case
PostGIS trac at osgeo.org
Wed Jun 18 12:04:58 PDT 2014
  Reporter:  jmccormick2001  |       Owner:  pramsey
      Type:  defect          |      Status:  closed
  Priority:  medium          |   Milestone:
 Component:  postgis         |     Version:  2.1.x
Resolution:  invalid         |    Keywords:
Changes (by jmccormick2001):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 strange, I found that for some reason bison/flex versions were different
 between my fedora and rhel box, I had copied the postgis source files from
 my rhel box over to my fedora box, ran make clean, and still I was getting
 bison/flex generate errors in the parsing of the WTK, I reinstalled
 postgis from the source tarball, recompiled and it now works....closing
 out.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2763#comment:1>
