[postgis-tickets] [PostGIS] #2755: 4 regression failures for sfcgal
PostGIS trac at osgeo.org
Wed Jun 18 08:19:50 PDT 2014
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  sfcgal   |     Version:  trunk
Resolution:           |    Keywords:
Comment(by vmo):
 Part of the problem came from r12350, which is reverted in the patch.
 The rest is from sfcgal regression tests that have not been run before.
 This patch has been tested against sfcgal 1.0, 1.0.4 and master. Some
 tests are expected to fail with master due to bugs that will be fixed in
 1.0.5.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2755#comment:5>
