[postgis-tickets] [PostGIS] #2755: 4 regression failures for sfcgal
PostGIS trac at osgeo.org
Mon Jun 23 12:02:08 PDT 2014
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  sfcgal   |     Version:  trunk
Resolution:           |    Keywords:
Comment(by pramsey):
 You can't just toss r12350, it's necessary to support extension upgrade,
 because during upgrade two libpostgis.so libraries are simultaneously
 loaded and they will collide on the GUC variable and upgrade will halt
 unless you check and avoid double-defining it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2755#comment:6>
