[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Thu Jun 19 06:24:17 PDT 2014
st_countagg(raster,integer,boolean,double precision) does not exist
  Reporter:  robe                   |       Owner:  dustymugs
      Type:  defect                 |      Status:  closed
  Priority:  blocker                |   Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Comment(by strk):
 Alright I think the problem is that
 ST_CountAGG(raste,integer,boolean,float8) was added somewhen during
 development but I've created the extension _before_ its creation.
 So moving from dev to devnext the AGGREGATE is documented as being already
 present in the source version (2.2.0dev already) and thus is not re-
 created. But it's _not_ present, so the upgrade fails to install it.
 This is a general problem with dev-to-devnext when it comes to aggregates,
 or generally to objects that the upgrade procedure now refrain from
 installing if advertised to be already present in the version.
 What we _could_ do is pretending all aggregates have to be dropped and re-
 created when source and target versions are the same and they end in
 "dev", or something like that. But I guess there would be still cases in
 which you'd want to avoid that.
 Or we could have a special "next"-like upgrade path for a full reload ?
 ALTER EXTENSION postgis UPDATE TO '2.2.0devnextfull' ?
 sounds like worth another ticket...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659#comment:20>
