[postgis-tickets] [PostGIS] #2765: Unable to find driver ESRI to unload from GDAL_SKIP environment variable
PostGIS trac at osgeo.org
Thu Jun 19 07:42:07 PDT 2014
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Traces from the first time raster library loads (PostGIS trunk):
 2014-06-19 16:40:14.968 CEST psql 8784 strk strk LOG:  statement: select
 st_asraster(st_point(0,0),1.0,-1.0);
 Warning 1: Unable to find driver ESRI to unload from GDAL_SKIP environment
 variable.
 Warning 1: Unable to find driver Shapefile to unload from GDAL_SKIP
 environment variable.
 Warning 1: Unable to find driver MapInfo to unload from GDAL_SKIP
 Warning 1: Unable to find driver File to unload from GDAL_SKIP environment
 variable.
 Warning 1: Unable to find driver UK to unload from GDAL_SKIP environment
 variable.
 Warning 1: Unable to find driver .NTF to unload from GDAL_SKIP environment
 variable
 This is with GDAL 2.0.0dev, released 2014/04/16
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2765>
