[postgis-tickets] [PostGIS] #2753: ST_Minkowski and ST_IsPlanar are documented but not installed (was: ST_Minkowski and ST_Planar are documented but not installed)
PostGIS trac at osgeo.org
Thu Jun 19 23:12:59 PDT 2014
 Reporter:  robe     |       Owner:  colivier
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  sfcgal   |     Version:  2.1.x
 Keywords:           |
Comment(by robe):
 I committed patch at r12626.  I revised to move the introduction stuff
 into the more standard section abstract rather than creating a whole new
 section and ref id which would cause problems in other ways.
 I see you added ST_3DIntersection so that is good but ST_Minkowski was
 still a problem
 I fixed those in r12627 and fixed my template in r12628.
 We still have the issue though that ST_IsPlanar is documented, but I don't
 see it installed.  Is this something that should be installed or should it
 be removed from docs?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2753#comment:3>
