[postgis-tickets] [PostGIS] #2753: ST_Minkowski and ST_IsPlanar are documented but not installed
PostGIS trac at osgeo.org
Fri Jun 20 00:29:38 PDT 2014
 Reporter:  robe     |       Owner:  colivier
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  sfcgal   |     Version:  2.1.x
 Keywords:           |
Comment(by vmo):
 Replying to [comment:3 robe]:
 > I committed patch at r12626.  I revised to move the introduction stuff
 into the more standard section abstract rather than creating a whole new
 section and ref id which would cause problems in other ways.
 Thanks a lot.
 > We still have the issue though that ST_IsPlanar is documented, but I
 don't see it installed.  Is this something that should be installed or
 should it be removed from docs?
 What do you mean by 'not installe' ?
 ST_IsPlanar is one of the functions that is replaced when setting
 postgis.backend to sfcgal.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2753#comment:4>
