[postgis-tickets] [PostGIS] #2777: Huge literal in enforce_max_extent_rast check constraint
PostGIS trac at osgeo.org
Mon Jun 23 09:31:42 PDT 2014
 Reporter:  strk    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:
Component:  raster  |     Version:  trunk
 Keywords:          |
 After importing a raster with this command:
 raster2pgsql -C -I -s 4326 -Y -t '256x256' -l 2,4,8,16
 The definition of the imported table has an "enforce_max_extent_rast"
 which uses a literal geometry value using 177,797 hex characters.
 Shouldn't it just be a 5 vertices polygon ?
 The constraint reads:
 "enforce_max_extent_rast" CHECK (st_coveredby(st_convexhull(rast),
 '<177,797 hex chars here>'::geometry))
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2777>
