[postgis-tickets] [PostGIS] #2777: Huge literal in enforce_max_extent_rast check constraint
PostGIS trac at osgeo.org
Mon Jun 23 10:21:23 PDT 2014
 Reporter:  strk    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:
Component:  raster  |     Version:  trunk
 Keywords:          |
Comment(by dustymugs):
 It currently is not the envelope or convex hull of the set of raster's.
 Instead it is the footprint. I'm fine with changing to a convex hull
 assuming robe2 doesn't see an issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2777#comment:1>
