[postgis-tickets] [PostGIS] #2783: Getting compile error when compiling json with custom json-dir
PostGIS trac at osgeo.org
Sat Jun 28 06:42:59 PDT 2014
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment(by robe):
 oh yippie deja vu and I learned down my excursion of history lane that
 strk originally took out the json from configure.ac and moved it to lwgeom
 http://trac.osgeo.org/postgis/ticket/2218
 r11119
 since this is likely only a windows version, I'm tempted to just upgrade
 the ones I have that use json 0.9 to newer (which I was goong to do
 anyway).  As long as we don't port back these changes to 2.1 nd 2.0 which
 we shouldn't need to do since we are not reading version numbers in those.
 And if we do I guess I can just upgrade to newer json chain on those.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2783#comment:9>
