[postgis-tickets] [PostGIS] #2783: Getting compile error when compiling json with custom json-dir
PostGIS trac at osgeo.org
Sat Jun 28 21:42:42 PDT 2014
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 I'm not going to bother with 0.9 anymore for 2.2.  Just upgraded 2.2 to
 use  static compiled json 0.12. Since this 0.9 issue is probably a mingw
 only issue, probably not worth fixing when newer json works fine.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2783#comment:10>
