[postgis-tickets] [PostGIS] #2794: winnie regress failures for sfcgal - 2 errors - seems scfgal.sql not installed (was: winnie regress failures for sfcgal - 2 errors)
PostGIS trac at osgeo.org
Sun Jun 29 12:51:59 PDT 2014
installed
 Reporter:  robe    |       Owner:  colivier
     Type:  defect  |      Status:  new
 Priority:  high    |   Milestone:  PostGIS 2.2.0
Component:  sfcgal  |     Version:  trunk
 Keywords:          |
Changes (by robe):
  * priority:  medium => high
Comment:
 Really odd. Seems winnie is not installing sfcgal script but even more
 odd, messages are completely different.
 On my local desktop running PostgreSQL 9.4beta1 I see this:
 Creating database 'postgis_reg'
 Loading PostGIS into 'postgis_reg'
 Loading SFCGAL into 'postgis_reg'
 PostgreSQL 9.4beta1, compiled by Visual C++ build 1800, 32-bit
   Postgis 2.2.0dev
  - r12688
  - 2014-06-29 18:42:33
   scripts 2.2.0dev r12688
   GEOS: 3.5.0dev-CAPI-1.9.0 r3985
   PROJ: Rel. 4.8.0, 6 March 2012
   SFCGAL: 1.0.4
 and all tests pass.
 and on winnie on her first test which fails the 2.2 chain I see this:
   /projects/postgis/branches/2.2/regress/00-regress-
 install/share/contrib/postgis/postgis.sql
 install/share/contrib/postgis/postgis_comments.sql
 PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
   Postgis 2.2.0dev
  - r12702
  - 2014-06-29 18:50:20
   scripts 2.2.0dev r12702
   GEOS: 3.5.0dev-CAPI-1.9.0 r3989
 note absense of sfcgal and message for install is totally different. I did
 a recent complete checkout on winnie and will do same on mine to rule out
 recent change or dirty stuff left.  Also bothered that the version number
 output on my desktop is wrong. It's almost like its using CREATE EXTENSION
 since the version is is spitting out is version I have installed in my
 PostgreSQL instance which is a recent build I installed from winnie.
 Perhaps its not doing the same on winnie -- because I didn't do a make
 install, so she might not have the extension files loaded in her instance.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2794#comment:2>
