[postgis-tickets] [PostGIS] #2794: regress sfcgal.sql install script fails to install with make check RUNTESTFLAGS=-v (was: winnie regress failures for sfcgal - 2 errors - seems scfgal.sql not installed)
PostGIS trac at osgeo.org
Sun Jun 29 13:13:35 PDT 2014
RUNTESTFLAGS=-v
 Reporter:  robe    |       Owner:  colivier
     Type:  defect  |      Status:  new
 Priority:  high    |   Milestone:  PostGIS 2.2.0
Component:  sfcgal  |     Version:  trunk
 Keywords:          |
Comment(by robe):
 AHA I found the smoking done - winnie was running with
 thus the more descriptive install message
 While my dev box is running with
 make check
 changed my desktop to do the same and it fails too.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2794#comment:3>
