[postgis-tickets] [PostGIS] #2382: Can't install postgis extension ERROR: attempt to redefine parameter "postgis.backend"
PostGIS trac at osgeo.org
Sat Mar 1 19:26:31 PST 2014
"postgis.backend"
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 see also #2658
 strk are you able to consistently reproduce the issue.  Sorry haven't had
 time to test upgrade this weekend but I think its only an issue with
 PostGIS 2.2.0 with introduction of GUCS (possibly 2.1 if you are running
 sfcgal too since that  has GUCs)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2382#comment:10>
