[postgis-tickets] [PostGIS] #2382: Can't install postgis ERROR: attempt to redefine parameter "postgis.backend" (was: Can't install postgis extension ERROR: attempt to redefine parameter "postgis.backend")
PostGIS trac at osgeo.org
Sat Mar 1 20:19:20 PST 2014
"postgis.backend"
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 strk,
 When I first saw this problem I thought it was just an extension issue.  I
 just tried the old fashioned way -- installing 2.1.2dev then upgrading
 with postgis_upgrade.sql to 2.2.0 and got the same error
 query result with 1 row discarded.
 ********** Error **********
 SQL state: XX000
 This is the sfcgal GUC isn't it that switches between geos and sfcgal
 backend.  I'm not sure why it's only an issue upgrading from 2.1 to 2.2
 and not 2.1.1 to 2.1.2dev etc.
 Where is this thing defined.  Doesn't seem to be explicit in the scripts
 so assume it's done in some postgis C function check.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2382#comment:11>
