[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Sun Mar 2 18:45:08 PST 2014
st_countagg(raster,integer,boolean,double precision) does not exist
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 after getting around issue #2382 by renaming my postgis-2.1 library, I get
 this error when trying to run the below from postgis 2.1.2dev (I cheated
 by copying the 2.1.1 install script -- I'll add to 2.2 next)
 ALTER EXTENSION postgis UPDATE TO "2.2.0dev";
 ERROR: function st_countagg(raster,integer,boolean,double precision) does
 not exist
 I didn't seem to run into this problem upgrading database using old
 fashioned way so might be an order issue or one of the drop extension
 thingy's.  I thought maybe the documentation was out of date, but went and
 ran raster_comments.sql on my old-fashioned upgrade to verify that was not
 the issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659>
