[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Mon Mar 3 00:50:12 PST 2014
st_countagg(raster,integer,boolean,double precision) does not exist
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by strk):
 When the upgrade script is created you should read WARNING lines on stderr
 for any aggregate function which does not contain a "Changed" or
 "Availability" label as a previous comment. That comment, in turn, drives
 when the aggregate is created and when not. In this case I guess such
 aggregate was introduced in 2.2.0. Does it have such comment ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659#comment:1>
