[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Mon Mar 3 03:46:11 PST 2014
st_countagg(raster,integer,boolean,double precision) does not exist
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Yes it does. It only breaks on extension install, not old-fashioned one.
 Also what do you do about new types?  This agg depends on new type: CREATE
 TYPE agg_count AS (
 and the new type has no Availability note.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659#comment:2>
