[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Mon Mar 3 09:29:21 PST 2014
st_countagg(raster,integer,boolean,double precision) does not exist
 Reporter:  robe                   |       Owner:  dustymugs
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 dustymugs,
 you might want to leave it up to strk to fix as I think the issue is with
 his autogenerated upgrade script and not your code comment.  The create
 type thing is a separate issue, which requires comment, but you have DODO
 code for that anyway.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659#comment:10>
