[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Mon Mar 3 09:31:12 PST 2014
st_countagg(raster,integer,boolean,double precision) does not exist
 Reporter:  robe                   |       Owner:  dustymugs
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by dustymugs):
 > Has this:
 > IF 202 > version_from_num FROM _postgis_upgrade_info THEN
 > Why is that 202 and not 220?
 I have no ideas. It doesn't look familiar...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659#comment:11>
