[postgis-tickets] [PostGIS] #2485: [raster]: raster constraints prevent raster data from restoring
PostGIS trac at osgeo.org
Tue Mar 4 00:16:34 PST 2014
 Reporter:  rdunklau  |       Owner:  dustymugs
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.0.5
Component:  raster    |     Version:  trunk
 Keywords:            |
Comment(by robe):
 I just thought of another possibly brilliant or really stupid work around
 for this issue.
 We explicitly add search_path to these functions something like
 ALTER FUNCTION _raster_constraint_pixel_types(raster)
   SET search_path=pg_catalog,public,postgis;
 I think we might even be able to do this in the code base too with the
 assumption that most people install postgis in public or postgis schema.
 I recalled a while back that PostgreSQL would complain if you added a non-
 existent search path, but lately I don't seem to be noticing that problem.
 rdunklau - if you are listing, the trick is to install postgis as usual
 with
 CREATE EXTENSION .. and then add these search paths to these select
 functions, and then restore your data.  This is the trick I've used in the
 past to allow be to get away with using ST_Transform in an index and have
 my indexes come back during restore.  Which had similar issues (by setting
 search_path of ST_Transform function)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:29>
