[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Tue Mar 4 05:06:23 PST 2014
st_countagg(raster,integer,boolean,double precision) does not exist
 Reporter:  robe                   |       Owner:  dustymugs
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Better -- now get this error when installing via extension upgrade:
 function st_astwkb_agg(geometry,integer) does not exist
 I assume coming from comments install.  Looks like nicklas didn't put in
 an availability note in the CREATE AGGREGATE def
 CREATE AGGREGATE st_astwkb_agg(geometry,int) (
 and the naming doesn't quite follow our new convention of only one
 underscore.  I'll ticket these as separate issue.
 Boy strk we are trapping all our sins with "Let's live by our comments"
 mantra.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659#comment:16>
