[postgis-tickets] [PostGIS] #2659: extension upgrade from 2.1.2dev to 2.2.0dev fails with st_countagg(raster, integer, boolean, double precision) does not exist
PostGIS trac at osgeo.org
Tue Mar 4 05:17:40 PST 2014
st_countagg(raster,integer,boolean,double precision) does not exist
  Reporter:  robe                   |       Owner:  dustymugs
      Type:  defect                 |      Status:  closed
  Priority:  blocker                |   Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 closing this out.  regular install seems to work (e.g. raster_comments.sql
 installs cleanly but postgis_comments.sql does not install cleanly because
 of the st_astwkb_agg issue)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2659#comment:17>
