[postgis-tickets] [PostGIS] #2665: Extension upgrade needs to selectively drop from extension aggregates and functions
PostGIS trac at osgeo.org
Thu Mar 6 00:29:17 PST 2014
functions
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 That's what I was asking in IRC about "do extension cleanly handle 'DROP'"
 You can test this with the new --upgrade-path switch of run_test.pl.
 If I'm not mistaken there's a script to replace DROPs with "DROP FROM
 extension; DROP..", not sure if that script runs over the whole upgrade
 script, needs to be checked.
 So please let me know which upgade path shows the problem for you.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2665#comment:1>
