[postgis-tickets] [PostGIS] #2665: Extension upgrade needs to selectively drop from extension aggregates and functions
PostGIS trac at osgeo.org
Fri Mar 7 05:27:09 PST 2014
functions
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by robe):
 none I have tested or think I CAN test since we haven't dropped anything
 that isn't in the drop before/after scripts.  I just scanned the generated
 extension script and expected for example where you have your
 autogenerated $postgis_proc_upgrade$ DOs
 like this case
 EXECUTE 'DROP AGGREGATE IF EXISTS ST_Extent(geometry)';
 it should be:
 SELECT postgis_extension_drop_if_exists('postgis', 'DROP AGGREGATE IF
 EXISTS  ST_Extent(geometry);')
 My sed script doesn't replace that construct since I think I only touch
 the drop/before after scripts to prevent from messing up plpgsql
 functions.
 Since you are doing an EXECUTE anyway wondering if maybe we should move
 the postgis_extension_drop_if_exists function up (rather create a new one
 that does your DO and drops from extension) as part of regular upgrade
 machinery and you just change your EXECUTE to use that new function.
 The only reason I had to create that function is because the drop from
 extension logic doesn't have a DROP IF EXISTS option, so the function just
 tries to drop from the extension and ignores if it gets an error (that
 means the extension doesn't have it).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2665#comment:2>
