[postgis-tickets] [PostGIS] #2674: Another count mismatch postgis 2.0.4 to 2.1.2dev one less operator
PostGIS trac at osgeo.org
Mon Mar 24 09:51:23 PDT 2014
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  new
  Priority:  blocker                |   Milestone:  PostGIS 2.1.2
 Component:  build/upgrade/install  |     Version:  2.1.x
Resolution:                         |    Keywords:
Comment(by strk):
 Ok, a way to reproduce:
 select count(*) from pg_operator where oprleft::int > 5000;
 Does give 44 on update and 45 on new install, looking at how I can add
 support for this check in run_test.pl
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2674#comment:14>
