[postgis-tickets] [PostGIS] #2674: Another count mismatch postgis 2.0.4 to 2.1.2dev one less operator
PostGIS trac at osgeo.org
Mon Mar 24 09:56:58 PDT 2014
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  new
  Priority:  blocker                |   Milestone:  PostGIS 2.1.2
 Component:  build/upgrade/install  |     Version:  2.1.x
Resolution:                         |    Keywords:
Comment(by strk):
 After thinking about this. It is clear that the correct way to test this
 would be for that missing operator to be tested in one of the regression
 tests.
 Dustymugs: do you know of an existing regress test testing operators ?
 I'm trying with runnign them all but getting lots of failures:
 ./run_test.pl --raster --extension --upgrade-path 2.0.4--2.1.2dev -v
 /usr/src//postgis/postgis-2.1/raster/test/regress/*.sql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2674#comment:15>
