[postgis-tickets] [PostGIS] #2684: can't upgrade from 2.1.2 to 2.1.2
PostGIS trac at osgeo.org
Thu Mar 27 04:52:12 PDT 2014
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 Regina, but... shouldn't that kind of upgrade be the same that happens on
 "make check" ?
 Or had you tried ./run_test.pl --extensions ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2684#comment:3>
