[postgis-tickets] [PostGIS] #2684: can't upgrade from 2.1.2 to 2.1.2
PostGIS trac at osgeo.org
Thu Mar 27 05:14:43 PDT 2014
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 Confirmed !
 [strk at cdb:/usr/src/postgis/postgis-2.1/raster/test/regress(svn-2.1)]
 ../../../regress/run_test.pl -v --upgrade --extension --raster tickets.sql
 PATH is
 /home/postgresql-9.3.1/bin:/home/postgresql-9.3.1/bin:/home/strk/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games://home/strk/bin://home/strk/bin
 Checking for shp2pgsql ... found
 Checking for pgsql2shp ... found
 Checking for raster2pgsql ... found
 TMPDIR is /tmp/pgis_reg
 Creating database 'postgis_reg'
 Preparing db 'postgis_reg' using 'CREATE EXTENSION'
 Upgrading PostGIS in 'postgis_reg' using 'ALTER EXTENSION'
 Error encountered altering EXTENSION POSTGIS, see
 /tmp/pgis_reg/regress_log for details
 [strk at cdb:/usr/src/postgis/postgis-2.1/raster/test/regress(svn-2.1)] cat
 createlang: language "plpgsql" is already installed in database
 "postgis_reg"
 CREATE EXTENSION
 ERROR:  operator = already exists
 Regina: could you add this step to the buildbots ?
 make check RUNTESTFLAGS=--extension
 Is only supposed to work _after_ "make install"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2684#comment:4>
