[postgis-tickets] [PostGIS] #2684: can't upgrade from 2.1.2 to 2.1.2
PostGIS trac at osgeo.org
Thu Mar 27 05:29:13 PDT 2014
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.2
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 Regina: the --extension switch to run_test.pl currently fails due to some
 tests being ambiguous when run in an extension environment due to raster
 being also forceably loaded. Those tests could be tweaked to be immune...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2684#comment:5>
