[postgis-tickets] [PostGIS] #2685: Regress failures against 9.4 development branch
PostGIS trac at osgeo.org
Thu Mar 27 14:16:08 PDT 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Debbie registered errors on last weekly regress against 9.4
 I'll rerun these again later to verify they are still an issue:
 this was against r12337 Sunday postgresql 9.4 snapshot
 Creating database 'postgis_reg'
 Loading PostGIS into 'postgis_reg'
 PostgreSQL 9.4devel on x86_64-unknown-linux-gnu, compiled by gcc (Debian
 4.4.5-8) 4.4.5, 64-bit
   Postgis 2.2.0dev - r12337 - 2014-03-23 03:07:16
   scripts 2.2.0dev r12337
   GEOS: 3.4.3dev-CAPI-1.8.3 r3967
   PROJ: Rel. 4.7.1, 23 September 2009
 Running tests
  loader/Point .............. ok
  loader/PointM .............. ok
  loader/PointZ .............. ok
  loader/MultiPoint .............. ok
  loader/MultiPointM .............. ok
  loader/MultiPointZ .............. ok
  loader/Arc .............. ok
  loader/ArcM .............. ok
  loader/ArcZ .............. ok
  loader/Polygon .............. ok
  loader/PolygonM .............. ok
  loader/PolygonZ .............. ok
  loader/TSTPolygon ......... ok
  loader/TSIPolygon ......... ok
  loader/TSTIPolygon ......... ok
  loader/PointWithSchema ..... ok
  loader/NoTransPoint ......... ok
  loader/NotReallyMultiPoint ......... ok
  loader/MultiToSinglePoint ......... ok
  loader/ReprojectPts ........ ok
  loader/ReprojectPtsGeog ........ ok
  loader/Latin1 .... ok
  loader/Latin1-implicit .... ok
  dumper/literalsrid ....... ok
  dumper/realtable ....... ok
  binary .. ok
  regress .. ok
  regress_index .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.4w64/test_28_diff)
  regress_index_nulls .. ok
  regress_selectivity .. ok
  lwgeom_regress .. ok
  regress_lrs .. ok
  removepoint .. ok
  setpoint .. ok
  simplify .. ok
  snaptogrid .. ok
  summary .. ok
  affine .. ok
  empty .. ok
  forcecurve .. ok
  measures .. ok
  legacy .. ok
  long_xact .. ok
  ctors .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  polyhedralsurface .. ok
  polygonize .. ok
  postgis_type_name .. ok
  geography .. ok
  out_geometry .. ok
  out_geography .. ok
  in_geohash .. ok
  in_gml .. ok
  in_kml .. ok
  iscollection .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_bdpoly .. ok
  regress_proj .. ok
  regress_management .. ok
  dump .. ok
  dumppoints .. ok
  boundary .. ok
  wmsservers .. ok
  wkt .. ok
  wkb .. ok
  tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.4w64/test_74_diff)
  typmod .. ok
  remove_repeated_points .. ok
  split .. ok
  relate .. ok
  bestsrid .. ok
  concave_hull .. ok
  twkb .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.4w64/test_91_diff)
  relate_bnr .. ok
  delaunaytriangles .. ok
  in_geojson .. ok
  uninstall .. ok (4226)
 regress failure outputs below:
 --- regress_index_expected      2014-01-15 22:24:34.000000000 -0800
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.4w64/test_28_out
 2014-03-22 20:08:45.000000000 -0700
 @@ -1,3 +1,4 @@
 +COPY 50000
  2594|POINT(130.504303 126.53112)
  3618|POINT(130.447205 131.655289)
  7245|POINT(128.10466 130.94133)
 --- tickets_expected    2014-02-08 20:06:27.000000000 -0800
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.4w64/test_74_out
 2014-03-22 20:08:53.000000000 -0700
 @@ -188,6 +188,7 @@
  #745|GEOMETRYCOLLECTION(POLYGON((-72 42 1,-70 43 1,-71 41 1,-72 42 1)))
  #1450|POINT|POLYGON
  #1482|4326
 +COPY 2
  #852.1|1|f|f
  #852.1|2|f|f
  #852.2|1|t|t
 --- clean_expected      2014-01-15 22:24:34.000000000 -0800
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.4w64/test_91_out
 2014-03-22 20:09:02.000000000 -0700
 @@ -1,3 +1,4 @@
 +COPY 28
  RT|1|t|t|f
  RT|2|t|t|f
  RT|3|t|t|f
 looks like some new output from new psql -- COPY
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2685>
