[postgis-tickets] [PostGIS] #2726: [raster]: POSTGIS_GDAL_ENABLED_DRIVERS not picking up all drivers listed
PostGIS trac at osgeo.org
Tue May 6 04:57:28 PDT 2014
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.3
Component:  raster   |     Version:  2.1.x
 Keywords:           |
 This could be a windows only issue, but if set this environment variable:
 @SET POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL
 and then do
 SELECT short_name FROM ST_GDALDrivers()
 ORDER BY short_name;
 I get:
    short_name
  AAIGrid
  ARG
  DTED
  EHdr
  FIT
  GIF
  GS7BG
  GSAG
  GSBG
  GTiff
  HF2
  HFA
  ILWIS
  INGR
  JPEG
  KMLSUPEROVERLAY
  NITF
  PNG
  R
  RST
  SAGA
  SRTMHGT
  USGSDEM
  VRT
  XPM
  XYZ
  ZMap
 (27 rows)
 However, If i set it like so:
 @SET POSTGIS_GDAL_ENABLED_DRIVERS="EHdr GTiff PNG JPEG GIF XYZ"
  short_name
  GIF
  GTiff
  JPEG
  PNG
 (4 rows)
 Note the absence of EHdr and XYZ.  Are those dependent on other drivers?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2726>
