[postgis-tickets] [PostGIS] #2726: [raster]: POSTGIS_GDAL_ENABLED_DRIVERS not picking up all drivers listed
PostGIS trac at osgeo.org
Tue May 6 05:00:21 PDT 2014
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.3
Component:  raster   |     Version:  2.1.x
 Keywords:           |
Description changed by robe:
Old description:
> This could be a windows only issue, but if set this environment variable:
> @SET POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL
> and then do
> SELECT short_name FROM ST_GDALDrivers()
> ORDER BY short_name;
> I get:
>    short_name
>  AAIGrid
>  ARG
>  DTED
>  EHdr
>  FIT
>  GIF
>  GS7BG
>  GSAG
>  GSBG
>  GTiff
>  HF2
>  HFA
>  ILWIS
>  INGR
>  JPEG
>  KMLSUPEROVERLAY
>  NITF
>  PNG
>  R
>  RST
>  SAGA
>  SRTMHGT
>  USGSDEM
>  VRT
>  XPM
>  XYZ
>  ZMap
> (27 rows)
> However, If i set it like so:
> @SET POSTGIS_GDAL_ENABLED_DRIVERS="EHdr GTiff PNG JPEG GIF XYZ"
>  short_name
>  GIF
>  GTiff
>  JPEG
>  PNG
> (4 rows)
> Note the absence of EHdr and XYZ.  Are those dependent on other drivers?
New description:
 Running:
 POSTGIS="2.1.3dev r12510" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24 GDAL_DATA not found"
 LIBXML="2.7.8" LIBJSON="UNKNOWN" RASTER PostgreSQL 9.3rc1, compiled by
 Visual C++ build 1600, 32-bit
 and then do
 I get:
    short_name
  AAIGrid
  ARG
  DTED
  EHdr
  FIT
  GIF
  GS7BG
  GSAG
  GSBG
  GTiff
  HF2
  HFA
  ILWIS
  INGR
  JPEG
  KMLSUPEROVERLAY
  NITF
  PNG
  R
  RST
  SAGA
  SRTMHGT
  USGSDEM
  VRT
  XPM
  XYZ
  ZMap
 (27 rows)
  short_name
  GIF
  GTiff
  JPEG
  PNG
 (4 rows)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2726#comment:1>
