[postgis-tickets] [PostGIS] #2726: [raster]: POSTGIS_GDAL_ENABLED_DRIVERS not picking up all drivers listed
PostGIS trac at osgeo.org
Thu May 8 23:58:11 PDT 2014
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.3
Component:  raster   |     Version:  2.1.x
 Keywords:  windows  |
Comment(by robe):
 Even worse news.  If I compile postgis with --enable-debug and then run
 SELECT * FROM ST_GDALDrivers();
 It crashes my server process.  At least it does it for both mingw and EDB
 so I have hope of determining where its happening with gdb.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2726#comment:4>
