[postgis-tickets] [PostGIS] #2726: [raster]: POSTGIS_GDAL_ENABLED_DRIVERS not picking up all drivers listed
PostGIS trac at osgeo.org
Fri May 9 00:20:13 PDT 2014
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.3
Component:  raster   |     Version:  2.1.x
 Keywords:  windows  |
Comment(by robe):
 Hmm seems to crash also if I run postgis_full_version(), but not
 postgis_version().  I think it's the postgis_raster_lib_version() doing
 it.
 Anyrate I ran:
 SELECT * FROM ST_GDALDrivers();
 and backtrace of crash looks like this:
 #0  0x000007fefd8e5a01 in strlen () from C:\Windows\system32\msvcrt.dll
 #1  0x000000000074df39 in fmtstr (target=0x23ce320, pointflag=<optimized
 out>, maxwidth=0, minlen=0, leftjust=0, value=0x0) at snprintf.c:779
 #2  dopr (target=target at entry=0x23ce320, format=0x39b131 "",
 args=0x23ce458 "A4ñü_\a", args at entry=0x23ce438 "") at snprintf.c:714
 #3  0x000000000074e13f in pg_vsnprintf (str=<optimized out>,
 count=count at entry=1023, fmt=fmt at entry=0x39b118 "[%s:%s:%d] GDAL_SKIP =
 %s", args=args at entry=0x23ce438 "") at snprintf.c:154
 #4  0x000000000057c0b1 in appendStringInfoVA (str=str at entry=0x23ce3e0,
 fmt=fmt at entry=0x39b118 "[%s:%s:%d] GDAL_SKIP = %s",
 args=args at entry=0x23ce438 "") at stringinfo.c:137
 #5  0x000000000071607f in errmsg_internal (fmt=fmt at entry=0x68701c5f
 "[%s:%s:%d] GDAL_SKIP = %s") at elog.c:821
 #6  0x0000000068684826 in rtpg_assignHookGDALEnabledDrivers () at
 rt_pg.c:112
 #7  _PG_init () at rt_pg.c:237
 #8  0x0000000000719b0c in internal_load_library
 (libname=libname at entry=0x4869818
 "C:/ming64gcc48/projects/postgresql/rel/pg9.3w64gcc48/lib/rtpostgis-2.1.dll")
 at dfmgr.c:284
 #9  0x000000000071a531 in load_external_function
 (filename=filename at entry=0x48b8e10 "$libdir/rtpostgis-2.1",
 funcname=funcname at entry=0x48b8dd8 "RASTER_getGDALDrivers",
 signalNotFound=signalNotFound at entry
 #10 0x000000000071b1ed in fmgr_info_C_lang (procedureTuple=0x4836c80,
 finfo=0x4868bb0, functionId=23562) at fmgr.c:350
 #11 fmgr_info_cxt_security (functionId=functionId at entry=23562,
 finfo=finfo at entry=0x4868bb0, mcxt=mcxt at entry=0x4863be0,
 ignore_security=ignore_security at entry=0 '\000') at fmgr.c:281
 #12 0x000000000071b508 in fmgr_info_cxt
 (functionId=functionId at entry=23562, finfo=finfo at entry=0x4868bb0,
 mcxt=mcxt at entry=0x4863be0) at fmgr.c:172
 #13 0x0000000000556592 in init_fcache (foid=23562, input_collation=0,
 fcache=fcache at entry=0x4868b90, fcacheCxt=0x4863be0,
 needDescForSets=needDescForSets at entry=0 '\000') at execQual.c:1310
 #14 0x000000000055b0ea in ExecMakeTableFunctionResult (funcexpr=0x4868b90,
 econtext=0x4867b68, expectedDesc=0x4868720, randomAccess=0 '\000') at
 execQual.c:2091
 #15 0x000000000056ed97 in FunctionNext (node=0x4867a50) at
 nodeFunctionscan.c:64
 #16 0x000000000055cfa6 in ExecScanFetch (recheckMtd=0x56ed20
 <FunctionRecheck>, accessMtd=0x56ed30 <FunctionNext>, node=0x4867a50) at
 execScan.c:82
 #17 ExecScan (node=node at entry=0x4867a50,
 accessMtd=accessMtd at entry=0x56ed30 <FunctionNext>,
 recheckMtd=recheckMtd at entry=0x56ed20 <FunctionRecheck>) at execScan.c:132
 #18 0x000000000056edc3 in ExecFunctionScan (node=node at entry=0x4867a50) at
 nodeFunctionscan.c:107
 #19 0x0000000000555898 in ExecProcNode (node=node at entry=0x4867a50) at
 execProcnode.c:426
 #20 0x0000000000552a0c in ExecutePlan (dest=0x48b51d0,
 direction=<optimized out>, numberTuples=0, sendTuples=1 '\001',
 operation=CMD_SELECT, planstate=0x4867a50, estate=0x4867938) at
 execMain.c:1470
 #21 standard_ExecutorRun (queryDesc=0x4843618, direction=<optimized out>,
 count=0) at execMain.c:306
 #22 0x00000000006441a6 in PortalRunSelect (portal=portal at entry=0x4855878,
 forward=forward at entry=1 '\001', count=count at entry=0,
 dest=dest at entry=0x4855878) at pquery.c:946
 #23 0x0000000000645876 in PortalRun (portal=0x23ceea0,
 portal at entry=0x4855878, count=0, count at entry=2147483647,
 isTopLevel=isTopLevel at entry=0 '\000', dest=0x4855878,
 dest at entry=0x48b51d0, altdest=altdest
     completionTag at entry=0x40000000020 <Address 0x40000000020 out of
 bounds>) at pquery.c:790
 #24 0x0000000000643146 in exec_simple_query (query_string=0x7fefd8e3fc0
 <msvcrt!__iob_func> "H\215\005\271ê\a") at postgres.c:1048
 #25 PostgresMain (argc=<optimized out>, argv=argv at entry=0x39aa68,
 dbname=0x17 <Address 0x17 out of bounds>, username=<optimized out>) at
 postgres.c:3985
 #26 0x00000000005f6b41 in BackendRun (port=0x23cf410) at postmaster.c:3999
 #27 SubPostmasterMain (argc=argc at entry=3, argv=argv at entry=0x2f7de0) at
 postmaster.c:4504
 #28 0x000000000075fb29 in main (argc=3, argv=0x2f7de0) at main.c:173
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2726#comment:5>
