[postgis-tickets] [PostGIS] #2729: [raster]: raster crashes when compiled with --enable-debug under windows
PostGIS trac at osgeo.org
Fri May 9 00:36:30 PDT 2014
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.3
Component:  raster   |     Version:  2.1.x
 Keywords:  windows  |
 I mentioned the issue in #2726
 I isoloated the offending line to
 rt_pg.c line 112
 POSTGIS_RT_DEBUGF(4, "GDAL_SKIP = %s", CPLGetConfigOption("GDAL_SKIP",
 NULL));
 so I remarked it out.  This might be just an issue under windows.  I don't
 have GDAL_SKIP defined (I have to recheck what happens if I do) and I
 think windows has issue with null strings so that might be the cause.
 Anyway not quite sure what to replace that with.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2729>
